Ron_Gratz
Aug 17, 2014Explorer
Gdetrailer wrote:I don't know why anyone would want to penalize him/herself by purchasing a too-small trailer just so the TV could tow excess trailer payload which would never be used. The TV doesn't care how much the trailer can weigh -- it only cares how much the trailer does weigh.
My take is to use the GVWR as your measuring stick for buying (even though your trailer could have a high Cargo rating you may never use).---
I've expressed my opinions on this issue several times. This time, I'll refer you to several posts written by another ORF member. Links to them can be found here.
An example post by "John & Angela" is copied below. I agree completely with the comments.
Using the trailer's GVWR instead of the expected GVW is likely to
1) result in your buying a TV which is bigger than you need or want,
2) result in your buying a trailer which is smaller than you want and smaller than your TV can handle, and/or
3) result in your buying a trailer with a relatively small CCC which could make it more likely that you would load the trailer to 100% or more of its GVWR.
QUOTING "JOHN & ANGELA"
The problem with using GVWR instead of GVW for checking compatibility with a tow vehicle is that it can take you out of a lot of higher quality units that use higher capacity components in their suspensions, frames, axles, brakes etc. A well known quality manufacturer has a model weighing in around 6200 dry weight. The GVWR is 10,000 pounds. If one has a truck capable of towing 9000 pounds for example they would not look at the unit if they are using the GVWR as a weight instead of a rating. They would effectively choose a lesser trailer only because its rating is LOWER. A 6200 pound 25 foot trailer even with a pack rat packing it would probably never come in over about 7800 pounds. It has also been my experience that the yellow tag is fairly acurate although I am not aware that includes propane and battery as any unit I have seen come from a factory doesn't have propane or battery included. This may vary depending on how it is ordered from the factory I suppose.
Although overestimating weight is always a good idea I think it needs to be kept real. GVWR is your friend. The bigger the better. Kinda like buying a truck. Do you look for a truck with a smaller rating or a larger rating. JMHO. I think even a rookie would understand that looking for a unit with a low rating vice high could turn into a safety issue fast.
UNQUOTE
Gdetrailer wrote:Nothing is ENSURED. Too much load in the TV can cause the towing capacity to be exceeded. Exceeding the trailer's GVWR can cause the towing capacity to be exceeded.
---Using the GVWR of the trailer ENSURES you will NEVER exceed the vehicles towing capacity and GIVES YOU ROOM to grow in the years to come.
If you believe that people are incapable of estimating and controlling how much they might load into the trailer, how can you be sure they will not load too much into the TV or into the trailer?
I choose to believe that people can make reasonable estimates and can control loading -- especially people who ask the kinds of questions being asked by the OP.
Ron
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
