- hsteinleExplorerThe acurite is hard to beat. If you use a 'wired' unit, then even a thin wire through the freezer/fridge gasket can cause problems. Be sure ANY battery type unit (like the acurite) that goes in the FREEZER has lithium batteries NOT alkaline, normal, or rechargeable. The lithium are not affected by the below freezing temps as are the others and will last longer.
- TrackrigExplorer III use one that shows four temps. Have one probe in the freezer, one in the refer, and one with a probe on about a 30" cord that hangs just the below the front end of the MH for the outdoor temp. The screen also shows the temp inside of the MH.
If you buy one, buy an extra sending unit or two because you may not find them in a couple of years when one quits working. That will save you from starting all over buying a totally new set up.
Bill - LarryJMExplorer II
Dutch_12078 wrote:
We use an AcuRite dual fridge/freezer remote reading thermometer. It shows us the two temps as well as min/max readings, and also has alarm settings to warn us if the temps get too far out of range.
AcuRite 00986 Refrigerator/Freezer Wireless Digital Thermometer
X3 and this is the best I've found after using 4 or 5 different ones.
I especially like the high/low continuous display along with the current temps.
Larry - sch911ExplorerI use my hand. Much cheaper, works well, and doesn't require batteries.
- ScottGNomadMine works so well that I just don't pay any attention to the temps inside.
- Nutinelse2doExplorer
X2 - rexlionExplorerI was using a wireless pair from Radio Shack, but I think the bouncing did it in. The outdoor unit that I had inside the fridge no longer sends to the indoor unit. I need to buy another pair of some sort.
- notruffinitExplorerI have a thermometer that was formerly one that was stuck on the outside of a window on our old coach. I is a digital thermometer that you can see through and it is only about an eighth inch thick. I also has a 24 hour memory. It is thin enough to slip in to the top door shelf. I like it because I not only get the current temp, but I can see the high and low for the day. I have found that the little fridge does a good job of holding temp!
John - Old-BiscuitExplorer IIIHey if it works why not.
Wireless weather stations are another means of monitoring food & freezer sections - Dutch_12078Explorer IIIWe use an AcuRite dual fridge/freezer remote reading thermometer. It shows us the two temps as well as min/max readings, and also has alarm settings to warn us if the temps get too far out of range.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 07, 2026
