RedRocket204
Oct 10, 2016Explorer
If you are at ~ 12% tongue weight, then your trailer weight is at 8000 lbs? It will not hurt, other than your wallet, to have a WDH so you are under the maximum stated hitch weight for your drawbar.
Speaking of drawbar, what size are you using? If your hitch states 800 lbs dead weight with 2" drawbar, what is it if you move up to a 2 1/2" drawbar?
EDIT: Just looked at Ford's 2016 Towing Guide and if you have the factory hitch, a 2" drawbar is 600 lbs and 2 1/2" drawbar is 850 lbs with no WDH. You may be more over than you are thinking.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
