mlts22's avatar
mlts22
What to pack for ice storms?
Of course, winter is still a ways off. However, for Texas, the time after October becomes prime camping season because one doesn't have to have a generator and A/C running for most of the day.
Blizzards are a non-issue in my neck of the woods, however the one thing that can strand someone in an area and cause serious problems for days are ice storms. Weather gets below freezing, rain hits, and in a few hours, not even four wheel drive vehicles with snow chains are going to help much with black ice.
What I'm trying to figure out is what to pack for an ice storm, just to have on hand if one hits while I'm boondocking. Currently, I already pack a few days of food/water, as well as plenty of gasoline for my generator. I even take a 12Ah portable battery so my electronic devices can be recharged at will if need be.
Other items I'm looking at:
1: A Big Buddy heater with a long fuel hose (so it can be piped through the electric cord mousehole and to a 20# propane bottle.) I normally would never use one of these, as the propane furnace is better/safer in virtually every way (except they use far more propane), but if there is an electrical failure or a battery dies, I would still have heat.
2: A few bottles of cheap vodka or RV antifreeze, whatever is cheaper. This would be used to flush the toilet with.
3: Two cases (24 total) of Coleman 16 ounce propane bottles. These would be used with the above mentioned propane heater or a portable stove.
4: An electric heater that would run from the generator if I ran out of propane entirely. I would likely have it run directly from an extension cord so there isn't any chance of overheating the rig's electrical wiring.
5: A propane stove and table to put it on.
Anyone have any suggestions for what else to bring, or have dealt with ice storms while camping?
  • " An electric heater that would run from the generator if I ran out of propane entirely. I would likely have it run directly from an extension cord so there isn't any chance of overheating the rig's electrical wiring"
    If your wiring is in such poor condition your afraid to plug in a heater you have bigger problems then ice storms. Your likely to create nothing but grief by running extension cords and propane lines. Your camper should be wired with 14 AWG wire .... your extension cord 16 or 18 AWG ..... much lighter wire not rated to carry 15amps.
  • I would want the same things I have at home - de-icer, sand, and salt.
    We camp during the winter around here - no big deal. We keep our furnace low (65-55) but keep it running for our heated underbelly. The heat radiating from the tt will melt the ice on it - they really aren't insulated that well. We keep our water tank full - more water takes a lot longer to freeze.
    We did figure out that the worst enemy is wind - with or without snow or ice. We were on top of a mountain in 25 mph winds during a snow storm. The wind sucked away any heat making it colder than it really was, forcing the furnace to work harder. A tarp blocking the wind from coming under the tt would have been very useful for conserving heat and protecting our water tanks.
  • Cash in small denominations. After an ice storm, or any disaster that can cause a power outage, gas station pumps, store cash registers, and ATMs will not work. Depending on the area of the country, power could be out for days or months. When an ice storm hit Mississippi years ago, 30% affected got power restored 6 months later. Plan on having a lot of cash because that 5 gallon gas container for your generator or car will probably cost $100-$200. A roll of TP in a store might cost you $10. Batteries AAA-D size, if you can find them, will probably sell for $10-$20 a piece. And there will be no such thing as change for your $100 bill, so stock up on smaller notes.
  • How long does a bottle of gas run the Buddy heater? Can you rig it up to run off the on board gas? Going for days swapping out the little bottles sounds like a hassle. Might be worth using the on board furnace although you'll need to recharge the batteries. When it gets cold and I need to run the furnace, I only get 1-2 days out of the 2 batteries. Many single battery setups don't make it through the 1st night.
  • A stack of blue tarps and a bundle of cheap bungees can save hours of work if deployed (to cover the rig) at the first hint of snow and freezing rain.
    A shake and a tug will remove everything.
  • A relatively common occurrence in the Carolinas. Often comes across the country from Texas, thru Atlanta. I've spent a few winter nights over the years in a SP or County park w/o electric due to ice storms. Short in duration, travel might be hazardous for just a couple or three days, tops. Power may be out for a couple of days. I've made it through just fine with 2 30# tanks of propane running the WH, furnace, cook stove and LP genny. Worst case experienced w/o electric was during the October Surprise in Buffalo, NY 5 or 6 years ago. Lake affect snow dumped a ton on top of the area. Damaged about 80% of the trees in Erie County. Leaves were still on the trees and when the limbs came down, so did the power lines. Went through 30#s of propane in 4 days. But, didn't miss a beat. Was warm, ate three meals a day, had a navy shower (4 season camper), satellite tv, Verizon air-card for internet, and made coffee for the linesmen working on the electrical grid in the area.:B Sounds like you're covered pretty well.
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 23, 2025
