WTP-GC
Aug 14, 2017Explorer
The Andersen levelers are a good product that just simply works. I know there are some people that have broken multiple levelers and thus consider them to be junk. But I don't understand how that happens. The only problem I have is that they can (and will) sink into softer dirt when loaded. As a result, I carry 2x8's and use them under the leveler's when needed. Sometimes, if setting up for more than 3-4 days, I'll use the 2x8's even if not needed, in order to mitigate settling. And if the ground is soft, the boards help to create a hard surface which helps against rig movement/shaking.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
