- Michelle_SExplorer IIII also do the Sunday Dump, but if it gets full before Sunday it lets us know by it's burp.
- Cummins12V98Explorer III
stickdog wrote:
If your a fulltimer do as we do and start with "BLACK TANK TUESDAYS".
I personally do a "Sunday Service" on both tanks. - VeebyesExplorer IIThose gauge lights are...well...full of it. We dump. One light is on. Make one or two 'deposits' & four lights are on again. This after doing a procedure that puts a few gallons of water into the tank to slosh around after dumping.
We stopped getting frustrated by those stupid lights long ago. We simply do a minimum of three days between dumps & don't go more than seven. - stickdogExplorerIf your a fulltimer do as we do and start with "BLACK TANK TUESDAYS".
- BobboExplorer III
DarkSkySeeker wrote:
MrWizard wrote:
If your gauges aren't working then use a flashlight and check it often
They work, but I don't get much "resolution". 4 LED lights that indicate full are not that helpful when trying to determine if the tank is full - full.
Easy Peasy, when the third light lights up, dump the tanks. If the fourth light lights up, you are past due to dump. - Mike_LeClairExplorerLet the flush & burp tell sign be your guide!
Cheers!
Mike - LwiddisNomadYou need to take a dump less often or dump your RV more often.
- DarkSkySeekerExplorer
2edgesword wrote:
We're old, irregular and never stay at a park for more than a week so the 40 gallon black tank never gets full.
At least you're honest. We've stayed a week while dry camping and the first thing (fresh, gray, black) to limit out is the fresh water. - 2edgeswordExplorerWe're old, irregular and never stay at a park for more than a week so the 40 gallon black tank never gets full.
- toedtoesExplorer III
For me, the gauge is a guideline. Once it says it's 3/4 full, it's time to start considering emptying the tank. I don't need it to be exact - I don't push the capacity to the extent that it will mean overflowing.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
