- filrupmarkExplorerWhen our black tank is full the toilet burps when you step on the pedal.
- bukhrnExplorer III
DarkSkySeeker wrote:
Most of them are notoriously incorrect anyways.MrWizard wrote:
If your gauges aren't working then use a flashlight and check it often
They work, but I don't get much "resolution". 4 LED lights that indicate full are not that helpful when trying to determine if the tank is full - full. - toedtoesExplorer III
For me, the gauge is a guideline. Once it says it's 3/4 full, it's time to start considering emptying the tank. I don't need it to be exact - I don't push the capacity to the extent that it will mean overflowing. - 2edgeswordExplorerWe're old, irregular and never stay at a park for more than a week so the 40 gallon black tank never gets full.
- DarkSkySeekerExplorer
At least you're honest. We've stayed a week while dry camping and the first thing (fresh, gray, black) to limit out is the fresh water. - LwiddisExplorer IIYou need to take a dump less often or dump your RV more often.
- Mike_LeClairExplorerLet the flush & burp tell sign be your guide!
Cheers!
Mike - BobboExplorer II
Easy Peasy, when the third light lights up, dump the tanks. If the fourth light lights up, you are past due to dump. - stickdogExplorerIf your a fulltimer do as we do and start with "BLACK TANK TUESDAYS".
- VeebyesExplorer IIThose gauge lights are...well...full of it. We dump. One light is on. Make one or two 'deposits' & four lights are on again. This after doing a procedure that puts a few gallons of water into the tank to slosh around after dumping.
We stopped getting frustrated by those stupid lights long ago. We simply do a minimum of three days between dumps & don't go more than seven.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
