Bobbo
Jan 27, 2022Explorer III
rhagfo wrote:
Well there is a difference between an "Outhouse" and a Vault Toilet. Most outhouses are just a cheap small room built over a hole in the ground. A Vault Toilet typically is a fiberglass or concrete building placed over a concrete Vault, that will hold the waist both liquid and solid, until pumped out and processed at a treatment facility.
cheap small room = room
fiberglass or concrete building = room
a hole in the ground = a hole in the ground
a concrete Vault, that will hold the waist (sic) both liquid and solid = a hole in the ground
until pumped out = other than cost to build, the only difference. :B
And, even then, an outhouse CAN be pumped out.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
