D_E_Bishop's avatar
D_E_Bishop
Where does the propane go?
Ol biscuit and I disagreed on whether or not is was possible for there to be air in a propane system basically with the tank valve shut and all the appliances turned off(valves shut). He said impossible but I say there is a gas(inert) in the system that won’t burn but will blow a match out.
As he said, it is a closed system and I agree, however, there is that gas flowing through the pipes that won’t burn. How is this possible? My system is all hard piping, no rubber hoses. I have never had an alarm that I didn’t want, i.e., testing of the alarm. Each appliance has at least three valves between the tank and the igniter and burner.
It makes no never mind, it is just that an inquiring mind wants to know. If I shut off the appliance, turn off the solenoid and shut the valve on the tank, where does the gas go? I’m sure there is a good answer, I just don’t think it is logical.
Any ideas from you experts?
  • 352's avatar
    352
    Explorer II
    Light a match and you will figure it out real quick.
  • The solenoid valves are not perfect. Also, LP is extremely temperature sensitive, so after the pressure reaches equilibrium, negative pressure will be created when the temp drops, drawing air back in to the system.
