EgorKC
May 29, 2013Explorer
Watts makes a PEX push on fitting line that mimics Shark Bites. The difference is they are all plastic. Had a factory crimp fitting (Vanity water supply) fail on our 4th night of use after purchase. It was a holiday weekend so our only option was call local mobile service tech. He undid connection, cut directly beneath crimp with a PVC snip, slid on watts supply coupling and screwed on. He then had me turn city water on while he checked for leaks. No leak. Took him longer to write the service ticket than the fix. I should add that Wildcat (Rod Batts is the warranty rep) reimbursed quickly with no problem. I went to our local Ace hardware when we got back and found that they stock the Watts fittings. I bought 5' of pex and couple Unions and water supply fittings to add to our RV tool kit. Cheap insurance. :)
Greg
Greg
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
