westend
May 29, 2013Explorer
Stars101 wrote:Don't know what you are finding for crimpers out there. FWIW, I did my whole rig with Pex and used a $25 die crimper (50 fittings). A 3/8" ratchet w/socket and a clean workplace made it easy to do. I did have the "go-no go" tool but after the first five I put it away. I haven't had a leak. I did use one Sharkbite fitting, from the existing copper supply line near the water heater to the new Pex. I Might have to put a bypass loop in at some time and the Sharkbite fittings are removable.
We just looked at a PEX crimper yesterday at Home Depot - $94.00!
"Only" $25 for the "cheapie" one that you need to use a pair of vice grips with. Horribly expensive when the manufacturer of your brand new TC screws up a crimp fitting and ya don't discover it until your are 5 hrs. from the dealer :) And if you need the tubing it comes in 25' rolls... when you only need a 6 inch piece.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
