Paul_Clancy
Aug 14, 2014Explorer II
Delam means the structure is failing. Laminated walls are part of what holds the unit together. If the glue fails the structure will fail. It is usually accompanied by wood rot in the roof/floors from the water intrusion that caused the glue to fail. Not always is it a water leak issue - it can be just a poor lamination job but manufacturers always blame the customers lack of roof maintenance first. This is why regular touchups with dicor and/or eternabond are so critical. If it was just cosmetic it could be lived with (not by me mind you) but it is not.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
