itguy08
Oct 03, 2017Explorer
mkirsch wrote:
Ford simply isn't confident enough in the EB engine to handle that kind of continuous work, and don't see enough of a benefit in designing a larger turbo gas engine to make it worthwhile.
It would be nice to have the option of getting the 3.5L EB in an F250 or F350, if you're going to use the truck for occasional towing only, but I'm sure Ford is afraid that people will order trucks in with EB's to do "real work" and be disappointed in the longevity of the engine.
Yet they are confident to put it in the Transit vans, which are subject to the same duty cycles of SD pickups - high loads, long periods of use, and maybe towing.
There's a lot of ignorance and whatnot in this thread.
From the people that complain about "turbos at 150k" and forget that Diesels run turbos too and don't get replaced that frequently. It's all in the DESIGN, which you can design for.
They also complain about a V6 forgetting that Big Rigs are I6's and even the much overrated Cummins is an I6....
I suspect the real reason is that it would tank Diesel sales. If I could get the benefits of Diesel (flat torque, no loss of power at high altitudes) with none of the negatives (expensive fuel and maintenance) why would I buy that expensive Diesel?
I own 2 Ecoboost 3.5's, one in a car and one in an F150. One with 118k and one with 82k. Both have been stellar powerplants and one tows a 9900 lb trailer just fine.
My next truck will be an F350 as we're wanting a 5th wheel as our next. If Ford put a Ecoboost 5.0 in there I'd buy that over a Diesel all day and twice on Sunday.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
