itguy08
Oct 05, 2017Explorer
2112 wrote:
The F250 weighs over 2000lbs more than an F150. I get 20.5 MPG running empty on the highway in my EB. If I dropped 1 ton of payload in my bed I would get probably about 12 MPG. Hitch a trailer to it and it would only get worse.
According to Google, a F150 Supercrew's curb weight is 4,487 to 5,238 lbs. A F250 Supercrew's curb weight is 5,683 to 6,695 lbs. Maybe comparing a light F150 to a Diesel F250 would get that 2k lbs difference but not gas engine to gas engine.
Should you drop 1 ton in the bed of your truck as, say dirt or gravel your MPG wouldn't be that bad at highway speed. The aerodynamics is mainly what kills MPG.
I tow a 11' tall, 35' bumper to hitch, 9900 lb GVWR trailer with a F150 EB. Highway I can get 10-13MPG if it's flat. 5-9 in the hills. About the same as a V8 but with more power.
None of us really knows the MPG of this mythical engine. Probably wouldn't be worse than the current 6.2 unloaded and about the same towing.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
