Ralph_Cramden
Jun 16, 2017Explorer II
GordonThree wrote:
Modifying your vehicle fuel system to provide a quick connect likely is illegal, I can't see USDOT or the NTSB approving anything like that.
How hard is it to carry a little gas can? If the answer too hard, get a propane conversion for your unit.
Who would be the arresting officer for this? Sgt Exxon of the royal mounted petrol police? :R
You do not want to tap into the TV fuel system mainly because its a high pressure system. As an example GM pickups run anywhere between 45 and 70 psi depending on year etc. That amount of pressure will pump out fuel in a hurry not to mention the system is designed to recirculate fuel. Altering the system is a good way to give yourself some expensive grief and maybe end up in a burn center while doing it.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
