TheLuvShack's avatar
TheLuvShack
Why run toad engine at every fuel stop?
Why run the toad engine at every fuel stop?
Is this recommended to keep the battery charged or lube the transmission or both. My toad battery charges through the umbilical cord. Will I damage the transmission by not running the toad engine for the recommended five minutes?
  • I get 600 miles on a tank of gas and travel usually 200 miles per day. What is the logic in running the toad at a gas station every third day
  • You must have an Chevy Equinox as your Toad. If so, yes, run the engine as recommended.
  • My manual says I don't need to do that so I don't. If it said to, I would.
  • "the smartest choice is to do exactly what the owner's manual says to do"
    Absolutely, right. Why jeopardize your vehicle's warranty?
  • Because it will make your toad last longer with fewer repairs. It provides some lube to vital areas.
    Do what you want, or do what someone tells you here to do, but the smartest choice is to do exactly what the owner's manual says to do.
  • the main purpose it to lube things. Just like you should run the engine before you take off in the morning, you should run the engine as per the vehicles towing documentation. It's not worth the risk of not following the instructions.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 08, 2025
