The heated hoses work fine, but are only a small part of the concerns during winter months. You really should try to determine if your TT has a "winter package" or not. You show as being from IL. Wintering there will be tough without a winter ready RV.
Keeping the interior heated will work to a certain temp (20 maybe), but as you go lower, plumbing will freeze if the utility area and holding tanks are not heated.
If you don't have double insulated windows, you'll need a really big propane tank to feed the furnace.
Do a lot of homework and be darned sure that you're prepared for the cold, or you can end up with a lot of expensive damage.
jerite wrote:
Ok I have a 2014 zinger travel trailer. So its new and bottom is covered well. So I feel confident that over the winter it should be usable. Now my question is how well does those heated water hoses work? Also what do you all use for sewer hose or pipe for sewer hook up in winter time? Any feedback will be appreciated. thanks in advance...Jer
