aftermath
Oct 01, 2018Explorer III
Right where the hose that goes into your gallon of pink is connected to the water line you should have a valve of some sort to turn. Some have asked if you have done this but you have not responded. The winterizing attachment has a valve that shuts out the tube and opens the pipe to your fresh water tank. Turn on the pump and it draws from the FW tank. Switch the valve and when you turn on the pump it will draw from the gallon jug of pink.
You shouldn't have to prime the pump if it is drawing fresh water before.
Nothing wrong with using air. I have done just that for 9 years without mishap.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
