old guy wrote:
I always cringe when some says just blow out the lines and forget the anti freeze. that might work in lawn sprinklers systems but when I did that on my first TT, I had leaks I had to fix before I could go camping the first time after that. Now I blow out the lines and use anti freeze. I only had to get burned once to learn my lesson. never lost a fitting again.
X2
The pex plumbing is a little more forgiving and will stretch a little but if you ever had to replace a copper system you would never rely on blowing it out again.
