DE88ROX wrote:
Dutch_12078 wrote:
DE88ROX wrote:
I went out and looked. The bottom valve directional arrow is pointing towards the water heater and the top is pointing away. From the diagrams i have seen that is correct.
The top valve is the problem then, since the water pressure is coming from the bypass line TOWARDS the heater, and the valve is letting it by. The valve will seal in one direction only when turned off.
You might be on to something. Think im going to have to take it in.
The way that top valve is installed, it would work fine as a hot water shut off, since the pressure would be coming
from the tank. For the bypass to work though, it needs to be installed the other way around. Or better yet, have them use Sharkbite, Watts, SeaTech, or some other brand valve that's not directional.
