willald
Jun 11, 2013Explorer II
The webpage you've provided a link to says that they charge off of 12V DC, so it seems like it would be easy to set up a charge cable from the toad to the bar...
Saw that. However, whether or not you leave it on a charge cable, the battery will eventually wear out. When it does, depending on how its wired, the lights may well not work even with the charge line connected. At which point, you'd then have to replace the battery.
..And from the looks of their documentation, its a very specific battery, so you might have a hard time finding a replacement by the time that battery goes out.
Sooo, like I said, yet one more battery to have to maintain, worry about, etc.
...without transmitter they wouldn't be much good to a thief however...
..If you're referring to the wireless light bar, you're right, it wouldnt be much value to a thief without the transmitter. Of course, it'd take the thief all of an extra 5 seconds to pull the transmitter off the back of your MH where you have it hooked to the 4 flat connector.
'Tis a common joke I've seen in the past when this subject comes up: Folks will ask the one thinking about buying one, to let them know when, where he'll be camping, so they can take it off his hands and sell it for a fast buck. :)
Will
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
