MiPaJacks's avatar
MiPaJacks
Wiring CRV to be towed by HR MH
I need to draw on you-alls experience to wire my 2009 Honda CRV stop and turn signal lights to be towed by the MH.
Just use the magnetic lights or is there something better and easier?
We are planning on a month long trip to the Grand Canyon, up to Brice Canyon and then to Mesa Verde, stay in Colorado a while, then back home to Dallas.
Like everyone I want to keep the cost down.
Thanks
James
  • Effy's avatar
    Effy
    Explorer II
    I just did this 2 weeks ago on our 2011 CRV.
    Couple methods,
    first is to use magnetic lights, this is the easiest however it needs to be done each time and you need to be careful about where you place the wires etc and hope it doesn't scratch your paint. The advantage to this method is that it's independent of the CRV, the downside is that it's not a permanent install and needs to be set up and removed every time.
    Second method is tapping into the CRV's existing wiring. This will require a little more work and some diodes so the CRV does not feed back into the MH. The advantage to this system is that it's permanent and a one and done install. The downside (some might not really consider it one) is that it's invasive into the CRV's wiring system.
    Lastly (the method I opted for) leverages the advantages of both of the above options. Drill and place an extra set of bulbs inside the tail light housing, and run the wires and plug for the MH to the front grill. While this option is likely the most work, it's probably the cheapest and I preferred this method because it's completely independent of the CRV wiring but it's also a permanent job. I used this kit.
    Blue ox light and socket kit
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
