joecolmav
Mar 17, 2017Explorer
wiring for flat towing
I'm new to flat towing.I just got a 2003 Tracker 4x4 2dr 5speed. I installed a blue ox base-plate with a Aladdin tow bar and a Patriot braking system. I will be towing it behind a 25ft Class C MH.
I need help with the wiring!!! Trying to figure it out is enough to make a guy drink!!!
I have 4 wires coming out of the MH. ground,park,lt turn/brake & rt turn/brake. My tracker has separate turn signal lights and brake/park light combos. I saw a system that uses 4 diodes, the diagram show that I would only use my brake/park on the tracker as brake/park&turn signals. I think I have that figured out. please tell me that this sound right/wrong.
Now what about my Patriot braking system? It will also try to put power to the brakes? Will that cause a problem?
Do I need to disconnect the battery? I need power to the Patriot.
Do I need a brake light relay?
Please someone tell me in simple terms what to do..
