Bobbo
Nov 05, 2015Explorer III
No. You can not run from the MH 7 pin to the Jeep's 7 pin. There are 3 options.
1. Use removable (magnetic) lights. They can be mounted on the back of the car or on a metal bar in the car's trailer hitch. No diodes needed.
2. Drill a hole in each of the car's tail light fixtures and install a new 1157 bulb/socket. No diodes needed.
3. Connect the wiring to the car's existing tail/brake lights. A diode is needed on each side.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
