HandyRandy
Nov 05, 2015Explorer
Quote ->My question is can I just mount another 7 way on the front of my Cherokee then run some wire back to my 7 way on the back of my jeep and splice it in? Or is there another way to do it. I don't really want to run portable lights if I don't have to.
Not sure, but probably not. Here is what I did:
I have a truck camper with the truck set up to tow trailers. I wanted to leave the 7 pin RV receptacle on the truck unchanged so I could tow a trailer or my '03 TJ interchangeably.
After a lot of research I ended up with the Roadmaster Invisibrake and decided to buy a pre-made tail light wiring/diode kit. On my jeep it was just a matter of unplugging the connectors to the tail lights and plugging the Roadmaster wiring in series. The RM wiring has Green, Yellow, Brown and ground wires that ran to the front of the Jeep. I mounted a 7 Pin RV receptacle on the front of the Jeep and built a "jumper cable" with a 7 Pin RV Plug on each end to span the tow bar. I just connected the Tail Light Green, Yellow and Brown to the same function contacts through to the truck connector.
My F350 "Towing Package" included a relay to isolate +12V so I ran this through the connector and a 20A fuse to keep the Jeep battery topped up - no diodes necessary.
The Invisibrake was supposed to use the Brown (running lights) wire for power, but I decided to take it directly from the (now charged) Jeep battery through a switch. The Invisibrake is supposed to interpret both Green and Yellow wires hot together as a Brake signal, but I used the Brake signal (typically Blue wire) from the truck connector to activate the brakes.
I called Roadmaster a couple times to ask questions and their tech support was great.
One reply above suggested leaving your key in the Off position to avoid discharging your battery, but if you a flat towing, you obviously need to leave your steering wheel unlocked to let the front wheels track.
Good luck.
Good luck.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
