Bird_Freak
Nov 07, 2015Explorer II
FIRE UP wrote:The cars I have done had separate lights from the running lights and brake lights. Installed in the tail light compartment your problem does not exist. Brake lights on toad brake or separate from coach t/s and brake.Bird Freak wrote:
last 4 toads I wired I just installed another bulb in each taillight and ran the wires straight to them. Never touched vehicle wiring.
Many folks do it this way. But, one of the main problems I see in wiring a toads tail lights this way is this. About 99.9% of the time, when a second bulb is added to the same tail light housing, it's ultra close to the original bulb. And, in the same percentage, there is no partition in between the two bulbs. And, if one has an auxiliary braking system, i.e. Ready Brake, Even Brake, Brake Buddy, and any other system that actually pushes on the brake pedal, then in a very, very large percentage of the toads out there, the brake lights are activated when the brake pedal pushed.
So, here's the potential scenario. You're all hooked up and towing down the road. You're approaching a turn and, you need to slow down. You apply the turn signal in the coach which, in turn, applies it to the additional bulb that's been installed in the toad. It's flashing, as it should be. But, you now apply the brakes in the coach. That, in turn, applies the brakes in the toad too, due to the auxiliary braking system installed in the toad.
If the toad is the same as approximately 90% or more out there in toad land, that auxiliary brake will activate the toads brake lights, correct?
So now, you've got a flashing bulb, most of the time, within approximately 1/2" to 1" away from a full brightness brake light bulb, with no partition between the two. What is a person following the toad, supposed to see?
Now, conditions will vary. One, the toad is one of the ones in the very small percentage that DOES NOT ACTIVATE THE BRAKE LIGHTS when the brake pedal is applied and, the key is in the off position.
Two, there is an actual partition in between the two bulbs.
Three, one is aware of the potential "dual bulb" conflict and, has remedied it in what ever way they did to alleviate the issue.
When most folks setup a toads lighting system, many are not aware that the auxiliary braking system they've chosen, not only pushes on the brake pedal but, by doing so, will activate the toads brake lights, even with the key completely out of the car. When they hook up to the coach and, run checks with their wife or, whom ever, all is good. But, the problem is, YOU'RE NOT MOVING.
It's a stationary check of the lights, not an in-motion one. It's hard to do an in-motion one.
People in RVing have been adding auxiliary sockets and bulbs for quite some time and, yes they work but, the potential problems in doing it this way are there. It's just something to take into consideration.
Scott
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
