6_7_tow_rig
Jul 17, 2013Explorer
cm11599ps wrote:
Can you say how you plan on hooking up the strip to the battery?
With alligator clips attached to the end of the positive and negative wires hooked to each battery post. I want to be able to completely unhook everything if I want with no permanent damage left behind. That way I can also unhook them from the battery when traveling so I know they cant come on while going down the road, or vibrate loose at the hard wire connection and cause a short somewhere.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
