1995brave
Jul 10, 2017Nomad
Your best bet is to go to the Winnebago website and download the wiring diagram for your RV. You probably have a front/rear A/C switch some where in the coach to switch between the two A/Cs while on 30amp power. So you have to wire up the separate 20amp power so it does not cross feed the 30 amp power. You probably have to have the switch set to the front A/C if using the generator wiring.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
