hausfrau's avatar
hausfrau
Wobbly Dinette Table? Here's why ...
My new trailer has a u-shape dinette slide-out. Wonderful idea, and we love the space, but after only 3 outings, the table is so wobbly, we can't use it. The single pedestal leg uses the typical cone-shape bases for the crimped-end leg. A close-up photo of the cone insert shows how the metal has fractured, making it unstable. The leg wobbles like crazy, both at the floor and at the table top. I've asked the manufacturer for a replacement. Here's the photo:
Photo of cone base for dinette table leg
  • ours cracked as well after about a year. we took the table out and put a regular 4 legged kitchen table in.
  • I think the problem with shaky tables that have two legs comes from the fact that the bases on the floor are not exactly lined up with the bases on the table. what I mean is they may be a little wider or farther apart on the floor than on the table, or the other way around. then in an attempt to get the table to not wobble we tend to whomp the table harder and harder each time it wobbles in an attempt to tighten the table driving the two taper legs that are out of alignment deeper till we crack the bases.
    when I removed my dinette and made new tables I just used one leg and it work's better for me, I think because there is no alignment problems.
  • Has anyone switched their dinettes to use this type of leg? It looks to be a lot sturdier than the 'pound it in harder' post legs we have now. I just got a replacement floor flange as I broke the one I had (1 of 2) by 'pounding it in harder'.
    Posts made for boats
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
