95jersey's avatar
95jersey
XL vs LT tires?
So thinking about getting some new tires this spring and moving up to either XL or LT tires. Not sure which is the better option for me? I have a 2018 F150 with OEM P tires now. Towing 6500lb (dry) (8000lb loaded) toy hauler with approx 1200lb hitch.
I only tow a handful of times (6-8) each year, so 90% is daily driving. I don't want a bone jarring ride 90% of the time, so is the XL tire a good compromise or should I just go LT?
  • Comparing two different classes of tire....
    The lower class tire, even though 'XL...extra load', till has to be de-rated a min of 9% of it's sidewall weight carry rating
    The higher class tire does NOT need to be de-rated as the "P" class tires used on pickups/SUVs/etc
    It is NOT all about weight carrying either. There are other attributes to tires...
    Wheels has ratings too...both weight carry and PSI
  • My wheels never had a pressure limit. If I were you, I would only look at e rated tires no matter what pressure you ultimately run.
  • Go for the LT tire. Handling while towing will be much improved.
  • Go to the "E" and air the same as before. Same pressures same load carrying.
    First you have to find the max pressure rating of your wheels. Xl tires are typically up to 41PSI and you can get LT tires in C,D,and E ratings (50, 65, 80 PSI). you'll need to match a tire to the max pressure your wheels can handle.
    Tire Rack rating and pressure chart.
    If you're current rig is within specs but you want to get rid of P-tire squish then XL's might do it. LT tires will give you a stiffer side wall and harsher ride to go along with the higher load capacity.
