I_Fish_2
Sep 24, 2014Explorer
Yet another, Atwood water heater problem
So, a week ago, the water heater started acting up. Sometimes it would work as it should, sometimes it would light and burn until the water was hot. When it did, it might not re-light when the water was running, and you'd end with a colder than wanted shower. Sometimes, it would burn a few minutes and shut off. Sometimes, it did nothing, as if it had a blown fuse.
I replaced the thermostat and eco, no fix. I took out the control board and had it tested, it failed. So, I replaced it with a Dinosaur board. Bingo, problem solved! It worked like a champ the last 3 days.
Until now. The wife used the shower, and the heater burned like it should. She's done, the heater heats and kicks itself off. A few hours later I go to take a shower, and I have hot water, but as my shower progresses, it gets cooler and cooler. When I get done, I check to see if the wife had turned off the switch, but no, it's still on. The red indicator light is not lit. I turn it off and back on, nothing happens, including the red indicator light. I checked the fuses, all good.
Oh, and the thermal cut-off switch, diode, or whatever? That's what the tech where I got the Dino board said probably caused the Atwood board to go bad. I was told to eliminate it. He said that was Atwood's instructions. I still have it, and may put it back in at some point, but it's not currently in the circuit, so it can be eliminated as a cause.
What am I missing?
What am I missing?
