westend
Nov 16, 2013Explorer
I have two battery banks, one controller, and one solar module. I chose to control the charge current from the solar with a battery master disconnect switch that has options of single bank or both banks charging. The negative phase is tied together with a buss bar in a separate box. I also have the inverter and converter switched in the same manner, that is probably overkill for most but I wanted the options to be available. Most of the time, all of the 12v system is connected in parallel.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
