Canadian_Rainbi
Nov 18, 2013Explorer
With 20 feet between batteries and only one 100 Watt panel and controller I would be tempted to charge the batteries one at a time. Install a battery switch at the output of the controller and run two sets of wires to the batteries. Charge one to say 80% then the other, then back to the first.
Trying to charge both at once would essentially put both your batteries in parallel. 20 feet is a long run for parallel batteries unless they are not providing much current.
OR as others have said one of the special controllers designed to charge two banks. Best, but more expensive.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
