doughere
Nov 19, 2013Explorer
If you are planning to use the one 100 watt panel while camping: I would tie the two batteries together, and wire the panel directly to the batteries (no controller). Watch the voltage and if it rises above 15 volts disconnect the panel.
If you are planning to leave the system alone (ie. storing the RV), tie the two batteries together and use one controller.
With one 100 watt panel, anything more than this is over-engineering a simple system.
Regards,
Doug
Regards,
Doug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
