landyacht318's avatar
landyacht318
"10 watt" LED
A while ago, as an experiment, I bought a 12v outdoor landscape light that claimed 10w warm white.
TO NO one's surprise it did not consume 10 watts, and while it did respond to a PWM LED dimmer, the range of adjustment was pretty poor so I did not use the dimmer thereafter.
It failed today. I'd estimate no more than 600 hours maximum total use.
When I feed it 13vDC, the LEd just flickers not close to coming on at full brightness. When i remove 12vDC is flickers once a bit brighter then flickers for a few seconds longer.
Now this was inexpensive, but to me it seems like a fairly good waterproof design, which can have a better LED attached to the fairly substantial housing/heatsink. with little effort. It did not get hot, merely warm, when it worked properly when new.
The circuit board driver does not have that burnt electronic smell, but could be blown for all I know.
They make a "20 watt" version of this light which employs the same housing, so I would be game to upgrade the LED emitter and electronics even if it costs more than buying a better product.
I could also add even more heatsinking.
Call it a learning/ keep it out of the landfill type of project.
I'd love to this housing contain a very powerful LED 12v light that responds nicely to a PWM dimmer, even though I do not really need one.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 07, 2025
