road-runner
Jun 08, 2018Explorer III
Most generators are rated in VA but advertised in watts. Converters give their specs in watts. Unless the converter is power factor corrected (most aren't), it's draw in VA is in the ballpark of 30% higher than its draw in watts. I've never seen a converter advertisement or spec sheet that mentions this. When the real numbers are run, a 1,000 watt generator has no chance of running a 60 amp converter at its full output. It needs close to the continuous output of a typical 2,000 watt generator.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
