SoundGuy
Jun 08, 2018Explorer
mike-uswest wrote:
Now I have a TT with a 60 watt convertor. Will my generator give this some power if the solar can't handle the clouds, or will it just shut the 1000 watt generator down? If it does, I will have to go generator shopping, and I like that Yamaha.
Not necessarily. At the risk of offending PD aficionados you could simply keep the EF1000iS you like so much, turn off the PD, and instead invest in a stand alone charger like this CTEK Multi US 25000 which does do a proper 14.4 volt bulk charge, offers temperature compensated charging, and won't overload your EF1000iS. You haven't indicated the size / type of battery or batteries you have but that would obviously determine just how long you may have to run your genset for sufficient recharge when the sun isn't co-operating as you would prefer.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
