SoundGuy
Jun 13, 2018Explorer
MEXICOWANDERER wrote:
Simplest fix..
mike-uswest wrote:
How is that hooked into the trailers wiring and hooked up to the generator? I know little about electrical hookups.
With due respect to MW and his recommendation for a charger that allows manually setting the charge voltage I'd suggest that since you "know little about electrical hookups" that you'd be far better served with one of the automatic chargers I suggested earlier. Either is Plug 'n Play - just connect it's charge cable to the batteries, plug it's input cable into the genset's 120 vac outlet, and let the charger do the thinking for you. No question, a manually controlled charger overall would be more effective but not if you don't know what you're doing with it. K.I.S.S. ;)
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
