wa8yxm
Aug 10, 2017Explorer III
THe Fantastic fan either draws outside air in or sucks inside air out (Causing other openings in the RV to draw in outside air.. You said the outside air was 110. So no, you do not have a problem. Other than not enough electricity
NOTE.. IN high temp areas like Los Vegas. some 30 amp only parks will let you draw power from TWO sites using a "Cheater box" Others will not. Ask management.
