Gdlow
Aug 10, 2017Explorer
RedRocket204 wrote:jerseyjim wrote:
You do NOT have a a/c problem. 102 degrees less 15 is all you're gonna get. Keep that fan off...as all that does is make things hotter.
Hmmm. 30' TT here with a single 13.5K AC 30A unit. Recently in Moab, set up in shade, but where daytime temp high was 108. I am able to keep the inside at 74 degrees.
Granted, I have completely resealed the inside on my trailer's AC unit with aluminum ducting tape and it made a very big difference in the ability for my trailer to keep cool. Prior to doing the reseal, it was very hard to keep the trailer under 86 degrees when it was 90-95 out.
OP, do yourself a favor and watch these short videos that gives an explanation why a lot of RV AC units do not cool very well. I really thought I was in need of a new AC unit but started doing some research and found multiple videos showing RV AC units are poorly sealed where gaps only continue to get worse over the years. A little time and a very inexpensive roll of aluminum duct tape can help a lot.
https://www.youtube.com/watch?v=E_GNjfFpTGU
https://www.youtube.com/watch?v=AzdQoDublzs
I will check them out..thanks
