westend
Jun 13, 2014Explorer
Two issues--120V receptacles not working, 12V system not charging.
The first issue is probably a GFCI or two tripped. This could be from a ground fault either in the RV or along the path to the source of power.
The battery issue is another issue and should be diagnosed with a multimeter noting voltages at the battery and back to any switches, circuit breakers, fuses, ant to the devices. If you have a fully charged battery, your lights won't be dimming.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
