MEXICOWANDERER wrote:
TWO RANDOM POINTS
Parallel means running alongside. Do not parallel either line or neutral to a 12 volt positive or chassis negative wire closer than 4" and then for not longer than 10 cm. This stops a lot of noise from entering the 12 volt line which can affect sensitive electronics, radios, televisions, etc.
Would it be a problem for other equipment such as LED lights, pump, etc.. or is it limited to TVs and radios? All my wiring will probably run in the same exact area, in some sort of plastic sleeve maybe.
I didnt plan on installing a radio and a tv, with a laptop, smart phone and bluetooth speakers I'll manage.
