SkiSmuggs
Feb 01, 2016Explorer
MrWizard wrote:SkiSmuggs wrote:
I am trying to avoid a bulky j-box in the cabinets. I am thinking something like the outlet multipliers (turns a dual outlet into 6), but mounts to a surface instead of plugging into an existing outlet.
You either had another outlet
Or install some kind of switch between the new cord and the existing outlet
You cannot connect the new power to existing outlet STILL connected to the RV wiring
And just plugging into the outlet with a make plug
Is called a "SUICIDE CORD "
Grab that with the inverter turned on and you will get shocked
Forget and leave it plugged in and connect to shore power or generator and you will fry the inverter, and maybe more
Fire is a possibility
Separate outlet or a cord no dunked ended plugs, no dual power simultaneous connections
This is from an inverter connected to the battery bank. The outlet would in no way be connected to the existing RV 110v circuits, but would be used when boondocking for the TV/DVD.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
