SkiSmuggs
Feb 01, 2016Explorer
DrewE wrote:
The wire running back could be Romex, or it could be an extension cord with the normal female end cut off and the wires attached to the outlet in some suitable manner. If it's Romex running back, you could attach a plug directly to the Romex, which should be OK if you don't intend to disconnect it except for servicing. Romex, or other solid wire, is not suitable for frequent bending and unbending.
Thanks, Drew, this answers the question as to why stranded wire to a plug. Since I will not be unplugging once in place, it sounds like I can run Romex from the receptacle to the inverter without issue.
However, if I use a j-box somewhere in between, I can run just one HD extension cord from the inverter to the j-box and Romex to both locations from there. I see the bedroom outlet only being used for an oscillating fan, and the E-center outlet for our 32" TV and a DVD player so not much total draw.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
