SoundGuy
Feb 01, 2016Explorer
SkiSmuggs wrote:
However, if I use a j-box somewhere in between, I can run just one HD extension cord from the inverter to the j-box and Romex to both locations from there. I see the bedroom outlet only being used for an oscillating fan, and the E-center outlet for our 32" TV and a DVD player so not much total draw.
For the use you've indicated nothing more than connectors, wire, and receptacles rated for 15 amp service is required - i.e. no need for anything "heavy duty" on the output side of the inverter, whatever you may mean by that. Just what is the rating of this inverter you're using anyway? :@
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
