SkiSmuggs
Feb 02, 2016Explorer
SoundGuy wrote:SkiSmuggs wrote:
However, if I use a j-box somewhere in between, I can run just one HD extension cord from the inverter to the j-box and Romex to both locations from there. I see the bedroom outlet only being used for an oscillating fan, and the E-center outlet for our 32" TV and a DVD player so not much total draw.
For the use you've indicated nothing more than connectors, wire, and receptacles rated for 15 amp service is required - i.e. no need for anything "heavy duty" on the output side of the inverter, whatever you may mean by that. Just what is the rating of this inverter you're using anyway? :@
It will be the Samlex PST-600 which is more than needed, but the lightest to support a remote. The idle draw is .5 amps, the same as the PST-300. By HD extension cord, I meant a heavy outdoor type vs the thin indoor cords. The heavy rubber is more abrasion resistant but I agree that it is not necessary for the proposed use. But then, one never knows what the future holds.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
