westend
Feb 02, 2016Explorer
wa8yxm wrote:
I do agree with "Why not run Romex"
But.. No reason other than the code you can't cut the end off a proper extension cord and wire on an outlet.. I suggest the outlet be a differnet color, RED or Orange, to indicate INVERTER power instead of the standard color, that is all.
I used these Hubbell I.G. receptacles for inverter powered receptacles. Pricy, but I had a few around, bought at clearance at the time. No mixing up the two different power sources.
The most elegant way of doing what the OP frames is to use a small transfer switch, wire directly to load center, and use the same receptacles as original. As to cost, the $60 transfer switch is probably going to be less than the installation of wire, receptacles, and boxes needed in the other manner.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
