Makin__Do's avatar
Makin__Do
12 volt to 110 ac - Is My Thinking All Wrong?
OK , I'll admit to being no expert when it comes to electrical matters, so put this question under the topic "will this really work?". I'm getting two new Lifeline 6 volt GPL-4CT AGM batteries. Since they cost $600 I'd really like to keep them "healthy". My battery isolator puts out 15.5 volts at idle, which always caused my wet cell batteries to be on boil most of the time. Now, I don't want to over charge the AGMs and the way I understand matters 15.5 volts is way too much of a constant charge. The only item drawing power going down the road will be my Engel DC fridge, which isn't drawing power all the time. So here's the real question: can I connect the isolator output to a 400 watt inverter and run a Progressive Dynamics 9245 on 110 ac from the converter and let it manage the batteries just like it would be doing if I were hooked up to shore power? Sounds like a plan, but would I just end up with toast?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
