  • I checked and it is a single hose unit. We have one on the boat (a lot cheaper than $2000 for a marine unit) but it does exhaust already cooled air pulling in warm moist air.
    It works OK but not nearly as good as a two hose unit.
    And it's a bit over 12amps AC not 130 amps. Solar is probably not practical for an RV.
  • 4,000 watt solar panel
    No hookups necessary. Wander indoors and outdoors without a single bead of swea.....er.....perspiration.
  • The reviews for some of their units I have looked at haven't been so good either.
  • The problem with it Haier I would not by one. I doubt there customer service has improved at all.
  • Almot's avatar
    Almot
    Explorer III
    MEXICOWANDERER wrote:
    ... power requirements
    130A @12V.
    Mex, let me know when you'll find a portable 4,000W solar panel :)
  • Versus NO TAX & Free Shipping through your living room window, we purchased an entire pallet of 5,000 BTU Goldstar AC units at Frys for $39.95 each, Goldstar is now LG. The year was 1997. No failures 16 units 2013.
  • 12,000 BTU portable A/C
    Soleus HCA-P12HP 12000 BTU Portable Air Conditioner, Fan, Heater and Dehumidifier.
    Portable on sale at Frys electronics, in Calif $399 (not Haier), combo a/C , heater, dehumidifier, heat pump, single hose , 12000 btu
  • sch911 wrote:
    marcsbigfoot20b27 wrote:
    Not bad.
    Only problem, it has only one hose.
    It will exhaust the hot air outside, but where does it suck the intake air to cool the condenser from??? It will create a vacuum in the room and suck in hot air from any crack or leak in the room.
    I would go with a two hose unit.
    No! IT's a hose within a hose for condenser air in/out. Yes not ideal. For inside, no vacuum in the room because it recirculates air for the evaporator airflow...
    You are saying it has a fresh air intake hose INSIDE the exhaust hose??? I doubt it....they have a dual hose model that is almost exactly the same.
    And yes it is for the CONDENSER cooling.
    The evaporator is the part that gets cold.
  • marcsbigfoot20b27 wrote:
    Not bad.
  • Not bad.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 08, 2026
