profdant139's avatar
profdant139
Explorer II
Jul 06, 2015
120W portable solar: works great! (and some questions)
We just got back from ten days in the Eastern Sierra – my new (well, “new to me”) 120 watt folding solar panels performed brilliantly. Easy to deploy, plug and play, and they kept the batteries fully charged, despite normal usage. Admittedly, these were perfect conditions – the panels were in the full, hot summer sun, with clear skies. But I was very impressed.
And now, the inevitable questions:
Do I need to disconnect the clips from the battery at night?
Is it harmful to leave the panels unhooked but deployed? I noticed that the red lights on the controller blink when I did that.
The panels seemed to attract dust and pollen, so I wiped them off once or twice a day. Is there a way to protect them from dust?
Can I clean the panels with Windex?
I’ve read that the controller is not rainproof, even though the panels are.
The controller is mounted under the panels, seemingly protected from the rain. Is there anything else that I can do to protect the controller? I don’t want to put it in a sealed plastic bag – I am concerned that it would overheat.
I am already planning a longer cable – it is now at 15 feet, which would be too short for most of our shady campsites. If I go to 25 feet, I know I will need heavier cable. Do I need to replace the cables running from the panels to the controller (which are a foot long), or just the cables running from the controller to the battery?
How long can the cable run go, from a practical perspective? I don’t mind the weight or bulk of heavier cable, if it will enable me to have 30 feet of cable or more.
Finally, has anyone built a platform allowing for easy rotation of the panels? Early in the day, I would like to point the panels toward the rising sun and then move them toward the south before leaving our campsite.
Thanks in advance for your advice!
  • Welcome to the world of solar.
    I use a damp rag to wipe my panels off in the morning. I wouldn't use Windex.
    No need to disconnect at night.
    Best thing you could do for the controller is take it off the panels and mount it close to the battery. Put the longer run between the panels and the controller, the short run to the battery. I've used 10 gauge for my portables.
    The light is blinking when you disconnect the battery because the panels are powering the controller. Most controllers want you to hook up the battery before having power coming in from the panels.
    BFL has the markey cornered on twirly thingies.
  • Quote:
    Maybe start with a Lazy Susan base & go from there ?
    Once the top & bottom sizes are determined, lock it down & drill holes on the outer perimeter of the top section going completely through the top & to the bottom section, about 1/4" deep into the bottom. You'd only need a couple of holes into the bottom, as the top would rotate around & line up with those couple holes. Use 1/4" by xx length pin to lock in place. Configure the panel supports & tilt as needed.
  • Just replace the cables from controller to batteries
    Why are you disconnecting the clips from the battery
    Not needed..that's why there is a controller
    You could build a "twirler" like you know who
    But that's one more thing to carry to and from camping
Having RV issues? Connect with others who have been in your shoes.24,302 PostsLatest Activity: Aug 18, 2025
